Technical Diagram Help This section is for help with technical diagrams from the staff.
Vacuum Line
Old May 29, 2010 | 05:27 PM
1969NeedsWork's Avatar
Default Vacuum Line
I have a 69 with a 350 and I put a rebuilt quadrajet on it yeserday (along with an engine dress up kit) the problem is mot of my vacuum hose were so old they cracked off while I was removing parts and now I have no idea where the lines from the carb plugged into.... The one on the front of the carb on the drivers side as well as the one on the passenger side of the carb???
There is also the round looking silver deal that is next to the coil that had a line to it also and I do not know where that connects to???
I was excited to get my Vette back on the road and now this
Any help would be great pictures would be even better!
Thanks in advance
Old May 29, 2010 | 11:32 PM
partsman41's Avatar
Most every shop manual will have a vacuum hose diagram in it,if you don't already have one,you should seriously consider obtaining one.
The line on the passenger side probably goes to the silver thing on the distributor. I'm not sure about the one on the driver's side,maybe the headlights or brake booster?
Ron
Old May 30, 2010 | 04:30 PM
I will give that a shot tonight and play with the other ones and see how far I can get! I needed to step away from it for a while! I am looking at getting a shop manual as we speak! I can not find one at any of the stores in my area of course!
Old Jun 18, 2010 | 12:23 AM
michelwillies's Avatar
most of many people have a draw vacuum line diagram. vacuum line is a typically diffusion pump.all Teflon and o-ring is a joint and vacuum is a seal it.nitrogen trap and gases are in vacuum line.many port is in vacuum port. so vacuum line diagram is provide information of many port in vacuum.vacuum line is main purpose of single manifold design.vacuum port is a independent of each other.
Old Jun 5, 2022 | 09:58 AM
I'm guessing the reason you couldn't post a video was possibly because it was the wrong file extension.
gym4866
Mar 11, 2009 02:23 PM
bruiserman
Jul 13, 2007 07:29 PM
bighank
Aug 18, 2006 03:31 PM
72and86
Jul 15, 2006 01:04 AM
rkm
Nov 28, 2005 08:47 PM
