Shift knob (im sorry if this is a dumb question)
Old Feb 25, 2006 | 11:48 AM
slw98vette's Avatar
Default Shift **** (im sorry if this is a dumb question)
i just bought a two tone shift boot and i was wondering how to get the shift **** and boot off so i can put the new boot on.
Old Feb 27, 2006 | 01:35 AM
Default RE: Shift **** (im sorry if this is a dumb question)
To remove your shift ****, check out my instruction web page at:
http://www.conceptualpolymer.com/corvette_install.htm
The boot is removed by pulling in its base towards the shifter shaft and then pulling upward. If I recall correctly, there are sheet metal clips or a ring that needs to be compressed slightly. You'll see what I mean when you start pulling the boot inward.
Old Feb 28, 2006 | 09:29 AM
While we are on the subject of shifters I have a question. The only Vette I have ever drove in my life is my own and one of the first things I noticed was that the shifter was (and still is) extremely stiff. So my first question is, how can I tell if I have an aftermarket shifter (like a short throw)? and my second question is, is there anything I can do to make the shifts more smooth? I've heard switching to Royal Purpule Trans Fluid can help make shifting smoother, but I wanted to get some opinions first. Thanx.
Old Mar 3, 2006 | 12:30 AM
Yes, if your shifter is stiff, in all likelyhood, you have a short-throw. I happen to enjoy the snick-snick of rapid-fire shifts; that's why I installed my BPP. Replacing the tranny fluid with synthetic will help, but it still won't be near a stock shifter, both in ease of use and in lengthy, cumbersome throws. A good compromise, I hear, is the C6 shifter. Its throw is shorter than the stock C5 shifter, but longer than a Hurst, BPP, Ripper, etc. Its main advantage, besides easier shifting, is its vibration isolation construction. My BPP buzzes after the tach hits 3500 rpm and I know why GM isolated the shfter shaft so much!
Old Mar 5, 2006 | 09:58 PM
I definitely like the shorter throws, I just wish it was a little bit smoother. I sat in a new Z06 at the car show last month and was playing around with shifter and it felt extremely smooth.
Old Mar 6, 2006 | 01:53 AM
The C6 shifter will bolt right in to your C5. The only thing is that you'll have to use a C6 shift ****.
Old Apr 15, 2006 | 03:05 AM
allegro's Avatar
I cut my OEM shifter off about an inch and really like the results. Very easy, very cheap mod.
click to enlarge
hsean
Aug 25, 2008 07:40 PM
PAY2PLAY
May 2, 2007 10:36 AM
eewiz
Dec 22, 2006 04:32 PM
Dave01
Oct 26, 2006 02:16 PM
hobbydays
Nov 20, 2005 02:49 AM
