Shift knob removal, automatic
How do you get the shift **** off? I popped out the button, and removed the retainer ring. The **** wont BUDGE! Is there a set screw? No mention in the GM service manual. Automatic. Thanks for advice.
96 LT1 yellow.
96 LT1 yellow.
Saw your post this morning. Unfortunately saw my dog heading for the door as well he's gotta go and I've got to get to work. Info is in the manual. When I get home tonite I'll sap you back.
Larry
Larry
Not sure if the 96 is the same but my 93 GM Service manual describes the following:
Remove shifter button by prying up, shift button retainer, snap ring, and shift ****. no mention of set screw w/ the automatic just the manual tranny. I took mine off a while back to replace the light (position indicator) and just strongarmed it loose after a little wd 40 the snap ring attaches around the control lever. Hope this helps.
Larry
Larry
Hi!! You'll need a set of snap ring pliers and then just enjoy yourself pulling it out! I did it to my '96 to put one of those neat-looking "carbon fiber look" shift *****.But before I put the new one on,I put a key ring with a little logo that I got at the Air and Space Museum.It reads, "REMOVE BEFORE FLIGHT"!!!!!
slw98vette
Apr 15, 2006 03:05 AM
