multi cd install
Old Jun 16, 2005 | 12:02 AM
tufgivup's Avatar
Default multi cd install
Hi...can anyone tell me if my c5 2000 coupe has a preinstalled wire that goes from my stereo to rear for multi cd hook-up...if it does have wire where would it be located...thanks much...Walter
Old Jun 16, 2005 | 08:09 PM
Default RE: multi cd install
if the same head unit applies for both setups, i woudl guess that if it doesnt have the wire run already, it is likely just a matter of hoooking it in.
Old Jun 28, 2005 | 12:48 AM
bmwdiver's Avatar
If it is equipted, when you pull out your radio you should see a smaller 10pin connector on the left side by the antenna cable. this cable runs all the way back to the rear center compartment. but unless your vehicle originally came equipted with the cd changer i doubt it is there, but on an up beat you can pick them up for a decent price on ebay. Good luck[sm=americanasmiley.gif]
scgennycars
Oct 1, 2006 11:41 AM
BIGHOCH
Jul 18, 2006 09:18 AM
markone
Jul 16, 2006 11:00 AM
oldvette
Mar 11, 2006 01:27 PM
fjules
Jul 15, 2005 08:23 PM
