73 Tilt Steering Column Removal
Old Feb 13, 2011 | 06:49 PM
73vettenet's Avatar
Default 73 Tilt Steering Column Removal
Hello All,
I have a 73 Stingray that I am attempting to remove the tilt and telescoping steering column to replace the rag joint. For the life of me I can't figure what I am doing wrong as the column will not come out.
Here are the steps that I went through:
1. Disconnect battery (of course!)
2. Remove the two 7/16" star bolts from the existing steering coupler. Tap in a small screwdriver in the part of the coupler closest to the firewall to open the coupler up.
3. Remove the reverse lockout cable by removing the cotter pin holding it in place.
4. Remove the clutch spring.
5. Inside of the car, remove the steering column cover - three Phillips head screws. Remove the AC duct.
6. Remove the two 1/2" bolts from the inside of the firewall.
7. Remove the two 9/16" bolts holding the column to the firewall.
Supposedly at this point the column should be removable...yet the thing just won't budge - even after repeating pulling and turning the air blue!
Did I leave a step out? Do I need to use more ommph to remove it?
Any guidance would be appreciated!
Old Feb 13, 2011 | 09:28 PM
partsman41's Avatar
There are 2bolts oriented vertically right where the column passes under the dash are those the 9/16 you mentioned? There will be a significant amount of gookum-puckey(scientific terminology) holding the thing to the firewall to seal the area against all kinds of leaks.
Ron
Old Feb 14, 2011 | 03:52 PM
73vettenet's Avatar
Hi partsman41,
Yes, the 9/16" bolts are the ones that are vertical under the dash - I typed firewall in step 7 when I meant to type dashboard....oops.
I guess I need to apply more elbow grease to get the thing to budge.
Thanks!
Old Feb 28, 2011 | 09:38 AM
Might try rotating the column to break it loose.
Gohot
Jun 19, 2012 09:42 PM
67bigblock
Jan 26, 2008 11:09 AM
jeff s
Jan 20, 2008 10:00 PM
TealC4
Aug 6, 2007 05:49 PM
Gorilla
Sep 16, 2005 02:36 PM
