c1 frames
Old May 21, 2006 | 04:32 PM
forum 2's Avatar
Default c1 frames
A newbi's plight.
Has anyone used any other frame to update their c1 corvette? I have modified my 62 frame to air springs, tubular 'a' arms/w rack and pinion steering. I also have air springs on the rear w/panhard bar. The frame is rusted and I would like to change frames and go with a center drive rear with the air springs, but am a loss as to what frame may be the easiest to modify. I am thinking of using A. Morrison's front half air spring frame, but it would require extensive fabrication, as I really want the center drive rear setup. Is there anyone here that has used another frame or modified one that would fit the c1 body? Thanks for any imput.
Don
Old Oct 18, 2006 | 12:05 AM
pav's Avatar
pav
Default RE: c1 frames
hi from fla..whatever you decide too do,,i am looking to buy a used, orgional frame, c1...thank you...charles...);;;;pavlu@webtv.net
Old Nov 2, 2006 | 09:31 AM
porchdog's Avatar
Corvette Correction sells a top shelf chassis. we are using one under the 57 restomod. the orig chassis is for sell .
www.corvettecorrection.com
kberjian
Aug 20, 2007 09:40 PM
pav
Sep 24, 2006 01:03 AM
Lee Willis
Nov 30, 2005 09:17 PM
