problem with 1989 can any1 help
Old Jul 5, 2005 | 10:00 PM
famous ralph's Avatar
Default problem with 1989 can any1 help
hi i am having a problem with my 1989 corvette the car seems to start up fine but if you turn it off it turns over but it wont start this happens for about 2 mintues then if i wait and try it again it will start.. after starting it and running the car it feels like it is running on 7 cyinders . i have replaced the plugs wires distribution and distributor cap rotor E.C.M. and the fuel pump... the problem is still happening can any1 help or have any info on this problem it would really help me thank u
Old Jul 6, 2005 | 11:22 AM
Doctor K's Avatar
Default RE: problem with 1989 can any1 help
It could be anything from a bad plug or wire to a dead cylinder, etc. Did the car run okay before you did the tune up? I hate it when a car does this. To save money and blood, sweat, and tears, I would take it to a local Corvette speciality shop and have them diagnose the problem(s) specifically. Cheaper in the long run!
Good luck
Old Jul 10, 2005 | 10:08 PM
wlaukaitis's Avatar
Hi!!
HOw many miles on this bad boy? I am nt sure how easy it is do do on a Corvette (I am still working on getting my '90) but when it is running, (badly) can you take the plug wires off to see which one DOES NOT make a difference?
I am just thinking a bad injector or something....
Old Jul 11, 2005 | 12:39 PM
DaveWJunior's Avatar
Default Or
As a variation to what the above poster said. To find a dead cylinder, I let the car cool down completely. Then, start it up and (carefully) check the exhaust manifold at each cylinder to see if they're all getting warm/hot. If one cylinder isn't firing, it'll be cool for awhile.
Old Jul 15, 2005 | 06:26 PM
Morgan's Avatar
Default RE: Or
Check your fuel injectors!
larrykim
Feb 25, 2007 09:13 PM
bobbobelair
Jan 20, 2007 09:24 PM
vwygonik
Feb 16, 2006 01:31 PM
lowmile89
Oct 11, 2005 11:42 AM
1989 BLOWNCONV VETTE
Sep 24, 2005 10:06 AM
