when engine heats up, rough idle & backfiring
Old Jul 2, 2006 | 10:41 PM
wandlwilliams's Avatar
Default when engine heats up, rough idle & backfiring
I have a 94 9K miles. Starts fine cold, runs fine for a few miles until engine heats up and then there is a miss in the engine. Runs real rough.
this problem started after I washed the engine but that was a month ago; plenty of time to dry out. Is there a connection or coincidence? thanks for any help.
Old Jul 3, 2006 | 01:33 AM
d93vette's Avatar
Default RE: when engine heats up, rough idle & backfiring
water and a opti-spark is not a good combo. if any water is in the opti-spark(any at all) it's gonna be a problem. two went south on me,the first after the engine was pressure washed. the second was a week after a huge rainstorm, both of them had to do with water. maybe theirs some water left and it steaming up the pick-up making it miss fire when its hot.
Old Jul 4, 2006 | 10:54 AM
I agree. If you have the old style Optispark distributor cap without the vent, then you probably have problems. The new style cap has a vent in it to rid itself of corrosion, buildup, water, etc. Only problem, you have to remove water pump to replace cap. [:@]
Old Oct 4, 2006 | 08:03 AM
bigalbeco's Avatar
I agree as well, but not a good idea to wash any electronic controlled engine. Cost my partner $80 for a new throttle position sensor 10 years ago on his Caddy! A customer came into my shop after washing a Jeep engine just before he was going to sell the Jeep and the transmission wouldn't shift, again, throttle postion sensor got wet. Live and Burn, Bigal
acossey
Oct 4, 2019 01:25 PM
Ty
Mar 22, 2011 11:58 AM
pappanick
Dec 15, 2008 02:31 PM
gearhaed
Oct 4, 2006 07:55 AM
90fredvette
Jun 15, 2006 01:01 AM
