Power Door Locks
Old Jul 31, 2005 | 05:20 AM
VETTELOVER's Avatar
Default Power Door Locks
I am having trouble trying to trace down my Power Door lock wiring ...Is there a seperate fuse for the Power door locks or is it on the same fuse with the horn..I know the servos are working because i tested them..I am not getting voltage to the switch ..maybe someone out there has had this problem..and can tell me exactly where to look ...1979 L-82 thanks in advance for any suggestions
Old Jul 31, 2005 | 10:38 AM
DaveWJunior's Avatar
Default RE: Power Door Locks
The wiring harness that connects to the switch is notorious for being bad/loose/corroded. It's a simple pin connector that sits inside the door and has been getting rattled and wet for over 20 years now. I can't recall which fuse is for the door locks. You said you checked and you're getting no power at the switch harness itself? Or does the switch just not do anything?
Come to think of it, I'm not even sure if mine work. I can't remember the last time I locked my car.
Old Jul 31, 2005 | 11:44 PM
VETTELOVER's Avatar
Iam not getting any power to the switch itself ....I was wandering if the power door locks are on the same circuit with the Horn ??
atragichope
May 29, 2009 03:42 PM
DeeVeeEight
Jan 17, 2008 10:53 PM
antjessash
Sep 9, 2006 08:08 PM
dok651
Apr 8, 2006 12:27 AM
maberry72
Mar 15, 2006 07:51 PM
