1980 UNDER DASH HELP
Old Aug 5, 2005 | 08:24 PM
jeepin45's Avatar
Default 1980 UNDER DASH HELP
I purchased a partialy restored 1980. I have most all connectors under the dash hooked up and in place but two connectors are wearing me out. One is balck with brown orange and red wires, the other white with 2 shades of pink a yellow and a brown wire. Any ideas?
Old Aug 6, 2005 | 11:19 AM
DaveWJunior's Avatar
Default RE: 1980 UNDER DASH HELP
can you post a pic? What area of the dash would they reach? Can you only get to them with the dash torn out, or just by looking into the footwell? Thick/thin wires? Let me know and I'll take a look at mine.
Old Aug 10, 2005 | 10:53 AM
jeepin45's Avatar
Here is a picture hope it helps
Old Aug 11, 2005 | 12:57 PM
If you get into your driver's footwell and reach ON TOP of the steering column, there should be 2 connectors there that you plug these 2 harnesses into. My connectors were a different color, but the wiring and pattern was the same. The white one will plug in closer to the steering wheel and the black one should plug in right in front of it (closer to the nose of the car). You can't see these connectors without using a mirror (or tearing the dash apart) so you'll have to do it by touch.
Hope this helps
pj_80shark
Dec 5, 2008 11:02 PM
Kevin98c5
Dec 4, 2008 04:52 AM
ZR1clone
Mar 23, 2008 09:33 PM
Jethro
Dec 26, 2007 05:11 PM
C3 Starship
Sep 25, 2007 11:40 AM
