86 AC/Heater fan problem.
Old Aug 22, 2005 | 09:28 AM
cmayberry's Avatar
Default 86 AC/Heater fan problem.
The AC/Heater Blower on my '86 only works on high speed intermittently. It will not work at any other speed. Fan test ok. Replaced switch with same results. Is there a relay somewhere I am missing? I am a newbie, by the way.
Old Aug 22, 2005 | 03:42 PM
Default RE: 86 AC/Heater fan problem.
my best bet is that your problem is the blower motor resistor
Old Aug 22, 2005 | 06:14 PM
cmayberry's Avatar
Do you know where that is located?
Old Aug 22, 2005 | 07:52 PM
i am sorry, i do not. if you call a dealership (parts department), they should be able to tell you if that is a common problem, and they should have schematics of where it is...
Old May 12, 2013 | 07:54 PM
Tarheel1's Avatar
Default re ac blower resistor
Under glove compartment
MarksGoldie1986
Oct 30, 2013 09:31 AM
vetterz06
Jun 25, 2007 06:03 PM
dan33470
Jun 3, 2007 09:19 PM
chxdigt
Apr 4, 2007 11:49 PM
Bagpipingjake
Oct 9, 2006 05:44 PM
