heater a/c fan not working
Old Jun 2, 2007 | 01:30 PM
dan33470's Avatar
Default heater a/c fan not working
95 LT1a/c& heater fan not powering on. All fuses ok, as well as the relay. Replaced command module in dash. Power is present at fan but it doesn't come on. Any one have suggestions? thanks
Old Jun 2, 2007 | 11:17 PM
Default RE: heater a/c fan not working
Make sure your ground wire to the fan is clean and tight. You can use a test light clipped to power and touch the ground wire to see if it lights up. If it does, then your blower motor is suspect.
Old Jun 3, 2007 | 09:19 PM
I'veowned two GM's with a loose blower connector - '98 Jimmy, and '02 1ton Express (bought new).
cmayberry
May 12, 2013 07:54 PM
DryCreamer
May 5, 2008 05:03 PM
JeffM7344
Apr 20, 2008 09:35 PM
anzolv
Apr 6, 2008 11:49 PM
ru10707
Aug 28, 2007 06:46 PM
