problem w/interior lights on 84
Old Aug 26, 2005 | 12:31 AM
ice11vette's Avatar
Default problem w/interior lights on 84
The other night I turned off the car to find that the interior lights wont go out. They acually came on while I was driving. So I pushed the light on the door panel and it still won't turn out. Tried again no luck. Thefloorboard lights, driver side door panel light, and the 2 lights behind the headrests will not turn off. I want to pull the fuse for them til I can find the problem, but I cannot find the fuse box.
Can anyone point me in the direction of where to locate the fuse box? Also any ideas of what my problem might be. Thx - for any help.
Old Aug 26, 2005 | 02:31 AM
kmhebert's Avatar
Default RE: problem w/interior lights on 84
I don't know where the fuse box is on that year. But there is a relay for the light that says if the doors or open or closed. I know on the older vettes it is behind the dash don't know about your year.
Old Aug 26, 2005 | 01:56 PM
ice11vette's Avatar
thx, I'll look into that.
anyone else have suggestions or know where the fuse box is?
Old Aug 26, 2005 | 04:28 PM
i thought that the fuse box was under the hood, and the drivers side?
Old Sep 16, 2005 | 02:23 PM
SkipS's Avatar
Your fuse box is located on the passenger’s side of the car. Just open the door and the box is behind the small panel at the end of the dash. Your problem is caused by an electrical piece under the dash. It is a small P.C. board assembly located toward the right center of the dash (unless someone has moved it around, earlier) if you put the fuse back in when you start looking for it that will help you locate the part. It will be hot to the touch. Good luck finding a replacement. They are getting scarce.
Old Nov 2, 2005 | 01:37 AM
rl08's Avatar
I have a 95 with the same interior light problem. Has anyone received anymore info?
blseals
May 18, 2007 06:23 AM
ryanoxj
May 5, 2007 08:11 PM
vette95
Apr 3, 2007 01:08 PM
Roman
Sep 29, 2006 04:19 PM
macadomac
Jun 22, 2006 09:40 AM
