headers for c-4
Old Dec 4, 2006 | 01:17 PM
89rdstr's Avatar
Default headers for c-4
which headers do you guys think are the best for a l-98 engine? where is the best place to get them? thanks for your input.
Old Dec 4, 2006 | 04:16 PM
Black86vette's Avatar
Default RE: headers for c-4
Depending on which brand you prefer. DO NOT GET HEADMAN!!!! I dont care if someone says they had a good deal with them blah blah blah. It will come back to bite you in the *** later down the road. JUNK. I like Hooker headers. Get them coated and they will dress up your bay, give you nice sound and add "roughly" 15 horsepower back to the car.
Hooker 2149 (with O2 bung, AIR pipes, and EGR, ceramic coated) I HIGHLY reccomend these. Everything works out and is provided. If you are a do it yourselfer, I have instructions on how to install headers if you would like. Hooker 16720 Y-pipe can be used with either.**New y pipe for headers**Good luck.
Old Dec 4, 2006 | 04:28 PM
Deleting AIR:
Alot of the manufacturers of headers make a set with the AIR pipes deleted. As I said above, AIR only functions on startup until the engine is warm, so you can safely remove it with no ill effects to emissions testing (provided you get the sniffer done when the engine is hot). You can cap off the lines on the headers or not, as the valves are supposed to be one-way only, likewise for the main cat. The AIR eliminator kit sold by many magazines does NOT give you any power, as the AIR pump is a fairly freely-spinning unit, but it does clean up the engine a bit and so is mostly a cosmetic mod. Any connections can be left alone as the L98 does not throw codes when AIR is removed.
Old Dec 4, 2006 | 04:29 PM
Catback:
Any of them should give the same 10-12hp gain. They all vary depending on the sound, shape, looks, ect.Corsa is best for those who do not like resonance (loud droning sound at around 2000rpm usually). There are many brands. The top ones that I reccomend are: Corsa, Borla, B&B, Flowmaster is good for sound but has low flowing capabilities and bad resonance.
Old Jun 13, 2007 | 06:43 PM
7191race's Avatar
*89rdstr I have just the headers for you. They have the AIR tube installed,and egr tube etc. Exotic Muscle, Tempe, Az.
Old Jun 13, 2007 | 06:51 PM
Don't know which are best but Here is a link. Have fun with it.
www.shopheaders.com
zzz06r
Jan 24, 2006 11:11 PM
tankerpilot01
Oct 6, 2005 12:15 PM
tankerpilot01
Sep 11, 2005 05:54 PM
erhard1
Aug 25, 2005 12:17 PM
desertwolf300
Jul 18, 2005 10:32 AM
