Horn
Old Dec 17, 2006 | 01:29 PM
blu85vette's Avatar
Default Horn
85 vette's horn doesn't work. Any suggestions.
Also, does anyone know where horn relay is located?
Thanks.
Old Dec 17, 2006 | 03:14 PM
Holeshot's Avatar
Default RE: Horn
Did you check your fuses?
Old Dec 19, 2006 | 11:29 AM
mariogarcia@usa.com's Avatar
Default RE: Horn
The horn relay is located in the middle console, up under the air vents, behind displays.
Old Dec 19, 2006 | 06:35 PM
94blackC4's Avatar
Default RE: Horn
If you find out that it isnt the Relay, post again because I had a problem with mine not working. It was the actual horn buttons. I will tell you more about it if you would like
Matt
Old Dec 20, 2006 | 09:42 AM
Default RE: Horn
Start at the horns and work your way back. Use a 12v test light at the horn wire to see if you have voltage at the horn first when pressing horn button. If not check your fuse, then continuity through horn pad (you will need a wiring diagram). The horn pad grounds the relay to provide circuit power to horns. Good luck. [8D]
bertsbassbox
May 20, 2006 03:15 AM
itzfrank
Mar 9, 2006 08:49 PM
pebblesjetson
Nov 28, 2005 02:08 AM
pebblesjetson
Nov 26, 2005 08:49 PM
jdavis
Nov 10, 2005 02:30 PM
