Horn Relay
Old Jul 26, 2005 | 11:18 AM
jdavis's Avatar
Default Horn Relay
I replaced the battery in the key fob & reprogramed, it had not had a battery in years. Everything worked great. Doors locked , alarm set, horn beeped good shape. TWICE! Now horn will not beep to signal that the alarm has been set. If you open the door thur the window with the alarm set it will not sound. You can hear a clicking in the dash as if the alarm has been set off but no horn. The horn will not even blow if you push the buttons on the steering wheel. I checked the fuse good shape?
Old Sep 27, 2005 | 10:49 PM
Ric's Avatar
Ric
Default RE: Horn Relay
I also have this same problem but its not from replacing battery in key fob.(I dont have the key fob)i have bin looking for three months and nothing helps my coeds show a short or high voltage in steering colum and I think its somthing to do whith vats system maybee key chip. If you find it let me know I am real intersted. good luck
Old Nov 10, 2005 | 02:30 PM
alienbeing316's Avatar
i also have the same problem, and would greatly appreciate it if u let me know if u get any results
frank j
Aug 10, 2010 05:46 PM
frank j
Jun 29, 2010 09:01 AM
CB
Feb 13, 2008 05:32 PM
bertsbassbox
May 20, 2006 03:15 AM
pebblesjetson
Nov 26, 2005 08:49 PM
