check engine light??
Old Apr 22, 2007 | 10:35 PM
xiongb1's Avatar
Default check engine light??
today I did the oil change andchanged the air filter on my 02' Z, and forgot to plug the mass air flow sensor back onto the car. I had turned the car on for a sec. and noticed CEL was on. I replug the mass air flow sensor back into the intake, and check engine light is still on??
Have I done something bad to it??
I don't get it at all. Anyone knows?
Thanks
Old Apr 22, 2007 | 11:15 PM
Default RE: check engine light??
Check that you reconnected everything well and then leave if overnight.Sometimes the codes clear themselves after a while. If its still on read the code and find out what the problem is.
Old Apr 23, 2007 | 12:18 AM
extanker's Avatar
disconect the batt for 5 min,s
Old Apr 23, 2007 | 11:13 AM
xiongb1's Avatar
yeah i pull the code and it shows four code that are "H". From my understanding if it's an "H" then I shouldn't worry about it? But if it's "C", then I should take care of it? Anyways i just went ahead and reset those "H" code, and check engine light went away.
cmittag
Jan 20, 2007 02:36 PM
CEILIA
Sep 20, 2005 07:40 PM
CEILIA
Aug 20, 2005 03:12 PM
rmd1960
Jul 31, 2005 11:13 AM
gerald452
Jul 21, 2005 08:24 PM
