94 wiper problem
Old Oct 7, 2005 | 02:58 AM
rodman's Avatar
Default 94 wiper problem
I just bought a 94 coupe and the intermittent wipers don't work. The slow and fast setting work fine as well as the mist and washer settings but there is no movement at all anywhere in the intermittent range. The wipers stop dead wherever they are when switched to intermittent. Any ideas?
[IMG]local://upfiles/861/0146F9FE7B8646E68B8003D835D71E54.jpg[/IMG]
[IMG]local://upfiles/861/EE0779EA6D9C4D36A2EA4EB772737C9F.jpg[/IMG]
Old Dec 1, 2005 | 09:13 PM
JCorvetteC4's Avatar
Default RE: 94 wiper problem
Rodman, does your cruise control work? I have the same problem and the cruise does not work. I will fix it this weekend and let you know. I think it is all the same problem and tied in to the lever where both are actuated. If you get yours fixed b4 I do let me know. Thanks
Old Dec 3, 2005 | 03:57 AM
rodman's Avatar
I do have trouble with the cruise. It works for a while and then quits. Then after a few minutes it will start working again. The first thing I thought of was the one common element as you mentioned but when I talked to a guy at the local corvette shop he seemed to think they were probably unrelated. I haven't had time to mess with it but I hope it works out for you. Thanks in advance for letting me know.
Alberto Martinez
Aug 17, 2013 10:02 PM
GMLOVER
Jul 4, 2009 07:36 AM
Nov 1, 2007 09:30 PM
farmetr
Oct 17, 2006 07:53 PM
keverson
Nov 4, 2005 09:26 PM
