OIL - LOW OIL
Old May 20, 2007 | 10:01 PM
xbob17x's Avatar
Default OIL - LOW OIL
I just recently purchased a Corvette and now my low oil light is on. I always check under where I park my car to make sure that there is no oil drips or anything. The guy who I brought the car off of said that the oil was recently changed and on the computer it said it was at 80%. I was wondering if the computer is accurate, is it common for my 2001 to burn oil and what I can do about this problem. Thanks.
Old May 20, 2007 | 10:42 PM
jerrysullivan's Avatar
Default RE: OIL - LOW OIL
The dip stick is the best judge of oil level......... good luck....8-)
Old May 21, 2007 | 12:13 PM
xbob17x's Avatar
I checked the dipstick and the oil level was just touching the bottom of it. I'm going to change the oil today.
Old May 21, 2007 | 02:06 PM
ORIGINAL: xbob17x
Yes, as long as the previous owner reset the oil life monitor, it should be accurate. 80% means that you have quite a while before you need to change the synthetic oil. I change my oil once per year (about 5500 miles). The manual recommends that you change your oil when the monitor reaches 0% or one year, whichever comes first.
Some early-year 2001s had an oil burning problem, primarily because of the piston rings. "Flutter" occurs during high-rpm downshifting and oil gets past the rings at an accelerated pace. Some 01 owners had the dealership replace the rings. My 01 is a very late year model and I add a quart every 2500-3000 miles or so, depending upon my type of driving.
Dave
shaggy34994
Feb 21, 2013 09:05 AM
z.oh.6
Jan 4, 2007 10:54 PM
87LtdT
Dec 31, 2006 04:57 PM
jdlag1
Apr 28, 2006 11:41 AM
Richvette
Oct 5, 2005 12:39 AM
