problem with my oil life reset
Old May 21, 2007 | 09:13 AM
kruser's Avatar
Default problem with my oil life reset
After getting my oil changed this weekend, when I hold the reset down to reset the "oil life remain" all I get is something like "Oil Life Remain _ _ _% " And it doesn't reset the change oil soon light. Any suggestions?
Old May 21, 2007 | 12:24 PM
Dave01's Avatar
Default RE: problem with my oil life reset
Is your ignition key in the "On" position?
Old May 21, 2007 | 05:16 PM
kruser's Avatar
Hi Dave, Yes, the car is in the on position when I reset it. Is it supposed to be in a different position? Thanks.
Old May 21, 2007 | 09:48 PM
Dave01's Avatar
Kruser,
The exact sequence is:
1. Turn the ignition to ON with the engine off.
2. Press the TRIP button so the OIL LIFE percentage is displayed.
Press RESET and hold for 2 seconds. OIL LIFE REMAIN 100% will appear.
Go ahead and try this again; it should work.
Dave
Old May 21, 2007 | 10:07 PM
tripleblack99's Avatar
Mine is a 1999 and after I change the oil I turn the key to the on position with the doors closed and hit the gas peddle three times, and it resets the oil back to 100%....
Old May 21, 2007 | 10:29 PM
Dave01's Avatar
Okay, it looks like things have changed after 99 or 2000. So our question is: What year is your C5, Kruser?
Old May 22, 2007 | 08:43 AM
kruser's Avatar
Hi Dave,
My C5 is a '98. I was able to reset oil life percentage using the steps you outlined above. I suppose the engine isn't supposed to be running when resetting. Thanks for you help.
DeclanS
Jan 25, 2013 10:48 AM
TJL74Vette
Jun 20, 2007 09:12 PM
serg5000
Jun 2, 2007 10:00 AM
hdstickel
Dec 9, 2006 09:44 PM
grabie
Apr 19, 2006 11:54 PM
