Heat/power window not working
Old Oct 10, 2005 | 12:41 AM
faleure's Avatar
Default Heat/power window not working
Hey everyone,
I recently bought a 1985 vette, and there are several problems I need to fix, but here are my main two:
1. Air blows out of all the vents, but the temperature on it is neutral. The AC won't blow cold, and the heater won't blow hot. There are no problem codes or lights stating any problems, so does anyone have any ideas?
2. The dash initially did not work at all. It's been fixed, but now the driver's side power window won't budge. My first step in fixing this will be to poke around under the arm rest to see if anything is loose, but does anyone have any suggestions in the meantime?
Thanks in advance for any help.
Old Oct 11, 2005 | 03:10 PM
faleure's Avatar
Default RE: Heat/power window not working
Okay, no answers so far.........would it help if I said that I took apart the center console and found out that the window issue was just a bad switch? That leaves the heater problem unsolved, and I'd be amazed if I could get that accomplished from the console.
Bad heater core, maybe?
atragichope
May 29, 2009 03:42 PM
DryCreamer
May 5, 2008 05:03 PM
bernie3
Jul 23, 2007 03:03 PM
Black86vette
Jan 28, 2007 09:00 PM
97C5 Owner
Sep 9, 2005 02:05 PM
