85" Cold Start Valve
Old Jul 9, 2007 | 11:07 AM
85L98's Avatar
Default 85" Cold Start Valve
I am a new member in this forum and a 1st time vette owner. I am very happy to find this forum and to be able to share valuable info
to and from members. My first question about the cold start valve is how can you check to see if it is working? The second ? is where
can i find a new one ? It seems to be a discontinued item. Not good news. [X(]
Old Jul 9, 2007 | 12:13 PM
Default RE: 85" Cold Start Valve
ORIGINAL: 85L98
You mean the cold start 'injector'?
What's goin' on that you think you might need one? How does it idle when started, and warmed up?
Old Jul 9, 2007 | 12:50 PM
85L98's Avatar
When i tyr to start the car it takes several rotations before the injectors supply enough fuel gor start.
afte that the car runs and idles ok.
Old Jul 9, 2007 | 01:29 PM
Superdzzz's Avatar
[sm=welcomesign.gif]
Congrats on your new baby!
First thing I would do is change ALL of the fluids and complete tune-up(wires, plugs etc...). Change all filters. Fuel filter is VERY important! But I say that a lot
Really recommend the K&N air filter for life
Glad to have you here!
Keep the wave alive[sm=icon_cheers.gif]
Old Jul 9, 2007 | 01:35 PM
ORIGINAL: 85L98
Any black exhaust when it fires?
Does it idle well, AFTER drivin' 10 minutes?
Old Jul 9, 2007 | 01:38 PM
Print this article, and put next to the john...
https://www.corvetteforums.com/m_37283/tm.htm
Old Jul 9, 2007 | 02:53 PM
85L98's Avatar
Thanks!
Old Jul 9, 2007 | 02:58 PM
85L98's Avatar
No black exhaust.
Runs good.
Old Jul 9, 2007 | 03:57 PM
ORIGINAL: 85L98
No black exhaust.
Okay, no black exhaust at idle = non rich condition. And MIGHT mean non-functioning cold start injector. In the middle of summer, I'm inclined however to NOT believe such is the case.
Check your fuel pressure. You said post 3 that you think it's fuel pressure. If you're convinced of this, then do the fuel pressure check, as per the article. If you're sure of this, there's NO REASON to do anything else other than that right now.
Do you hear the fuel pump prime the fuel rails, just before you pull the trigger on the motor?
ORIGINAL: 85L98
Runs good.
If it runs [IDLES] good after a short drive, completely steady, A/C off, this is very good. Means no vacuum leaks. And means you can check off 'air', from air, gasoline, fire checklist.
Check the fuel pressure.
Old Jul 10, 2007 | 02:33 PM
85L98's Avatar
Fuel pum new. Fuel pressure-42--?
