85" Cold Start Valve
I am a new member in this forum and a 1st time vette owner. I am very happy to find this forum and to be able to share valuable info
to and from members. My first question about the cold start valve is how can you check to see if it is working? The second ? is where
can i find a new one ? It seems to be a discontinued item. Not good news. [X(]
ORIGINAL: 85L98
What's goin' on that you think you might need one? How does it idle when started, and warmed up?
[sm=welcomesign.gif]
Congrats on your new baby!
First thing I would do is change ALL of the fluids and complete tune-up(wires, plugs etc...). Change all filters. Fuel filter is VERY important! But I say that a lot
Really recommend the K&N air filter for life
Glad to have you here!
Keep the wave alive[sm=icon_cheers.gif]
ORIGINAL: 85L98
When i tyr to start the car it takes several rotations before the injectors supply enough fuel gor start.
afte that the car runs and idles ok.
Does it idle well, AFTER drivin' 10 minutes?
ORIGINAL: 85L98
No black exhaust.
No black exhaust.
Check your fuel pressure. You said post 3 that you think it's fuel pressure. If you're convinced of this, then do the fuel pressure check, as per the article. If you're sure of this, there's NO REASON to do anything else other than that right now.
Do you hear the fuel pump prime the fuel rails, just before you pull the trigger on the motor?
ORIGINAL: 85L98
Runs good.
Runs good.
Check the fuel pressure.
