69 Vette headlight replacement??
Old Oct 23, 2005 | 06:15 PM
dwhite's Avatar
Default 69 Vette headlight replacement??
I just picked up a 69 and don't have a manual yet. I need to replace a low beam headlight. I have the bulb, but is this done from uner the hood, or from the front? Your help is appreciated. dan
Old Oct 23, 2005 | 10:59 PM
red70vet's Avatar
Default RE: 69 Vette headlight replacement??
It unplugs from the back but is removed from the front. Unscrew the trim ring and remove the headlight. You will probably have to remove the bezel around the headlights to get to the trim ring.
monte_350
May 14, 2022 02:02 PM
808amp
Oct 1, 2010 08:21 PM
yayaman
May 26, 2008 05:21 PM
hc91237
Oct 28, 2006 05:32 PM
81GAVette
Technical Diagram Help
Oct 17, 2006 07:18 PM
