traction control system?
Old Oct 25, 2005 | 11:56 PM
mark m's Avatar
Default traction control system?
can use any help from you guys. am getting warning light service traction control system
reduced engine power,any ideas.
Old Oct 27, 2005 | 10:24 PM
Default RE: traction control system?
Exactly what happens? Does the light come on all the time? Only in some situations?
If you really have the reduced power evoking itself, you can hardly drive the car (it has, at most, 20 HP, just enough to move it somewhere safe.
There may be nothing wrong with the traction control. I've received this same error code many times and it has never been about the traction control itself -- always about the engine controls. Have you modified or played with the engine at all, particularly the thorttle body or MAF? The message is common if you haven't re-hooked up the wires tightly to the passenger's side of the throttle body.
Old Oct 27, 2005 | 11:39 PM
mark m's Avatar
hey thanks for your help. looks like it turned out to be a couple of things. accel pedal assm. and
tps sensor i hope!!
Old Oct 28, 2005 | 09:32 AM
Well, I hope it is that, but . . .
I had this problem repeatedly about 2 years ago. The electronic thrttle assembly and the TPI sensor were both replaced twice (if you have the manual, you can check the codes and see that is what it recommends to do).
turned out it was a loose wire junction in the wires leading to the TPI. Sometimes it would intermitantly open the circuit and the engine computer would go berserk. ((We have put a supercharger on the car and disconnected, then reconnected the TPI wires to route them around the SC, and we apparently bent a pin in the connector))).
Good luck.
Old Oct 28, 2005 | 10:47 AM
mark m's Avatar
all sounds good thanks for the imfo,hopefully i've corrected the problem
tedro
Dec 10, 2006 11:17 PM
tedro
Nov 14, 2006 10:02 AM
seapup0
Oct 20, 2006 10:35 AM
50annv03
Apr 19, 2006 05:56 PM
raymond1ford
Aug 20, 2005 05:19 PM
