82 Starting Problems
Old Aug 28, 2007 | 12:42 AM
Physco82's Avatar
Default 82 Starting Problems
I have a Crossfire Injected Vette. I jusy finished going thru the engine and suspension and Finally was able to put key to ignition and hear her roar. Wich of course she did with out hessitence but after statring her a couple of time she will not start any more. I have great spark and my timing is dead on. I even ran compression checks on all the cylinders just in case (130 # + per cylinder). I am now completly frustrated and dont know what to do. Please Help
Old Aug 28, 2007 | 05:17 AM
78buckshot's Avatar
Default RE: 82 Starting Problems
Hi Physco82, you need compression, spark, fuel, and oxygen to make fire in the combustion chambers, it sounds like you have most of them-sounds like it's not getting fuel. Also you did not mention if the engine is turning over when you hit the key, is it a cranking problem or one of the above? Get back to us, we'll have it runnin' in no time.
Old Aug 28, 2007 | 11:29 PM
Spark, comp, and I'm sure lots of air. Takin' a long shot here, but what about a clogged fuel filter? Ya could have sucked some crap into the last little hole in the filter.
95trplblkandtan
Aug 6, 2007 07:00 AM
vrooomm
Feb 7, 2007 06:48 PM
red90vettesc
Dec 31, 2006 12:29 AM
maberry72
Jul 29, 2006 12:36 AM
footdoc
Jun 30, 2005 11:34 PM
