New-b question..
Old Nov 2, 2005 | 07:29 PM
00BlkHardTop's Avatar
Default New-b question..
Hello all! Just picked up a Corvette and was wondering what PSI (for the tires) will make the car happy? It keeps beeping at me everytime I get in.
Thanks for the first-time help!
Old Nov 3, 2005 | 02:30 AM
Default RE: New-b question..
The correct pressures will be posted on a door jam, or in the owner's manual. If they aren't stock tires then you'll have to lay with it 'til it feels good. I have 275-35-18s on the front at 35 lbs and 345x18 drag radials on the rear at 27 lbs, but this is less than you run stock tires, I know.
Old Nov 9, 2005 | 04:29 PM
BlueLineDvr's Avatar
Hardtop,
I've got stock rims/tires and run 32psi. But with the advent of winter (I'm in Illinois) and the temps dropping the PSI will drop too. My 32 now starts out around 27 or as low as 25. Just have to play with the pressure more during cold weather.
Old Nov 13, 2005 | 11:09 PM
...depends on the type of tires. If you have the runflat Goodyears, then make sure their pressure doesn't get much past 30 when hot. This means that the "cold" pressure will be higher during Winter months. My experience has been if I set the pressure at 30 while the tires are cold, the center part of the tread would wear out faster than the outside areas, indicating that the pressure is too high.
Old Dec 10, 2005 | 02:31 PM
Batmbl's Avatar
ORIGINAL: Dave01
I am running the non-RF Falkens -- love them. I keep pressure at 32, but check it regulary, esp. in winter.
ednev
Feb 10, 2012 02:08 PM
