Professional Racing NASCAR, Formula 1, Sprint, Rally & Off Road, SCCA Auto X, Le Mans, Pro Stock, Cart, Drag, IROC, etc.
Autocross suspension set ups
Old May 31, 2005 | 01:06 AM
docmbnbkos's Avatar
Default Autocross suspension set ups
I would be interested in suspension set ups for autocross and engine set ups at well, but mostly suspension. What spring rates front and back, what ratio of antiroll for what driving characteristics, understeer, neutral steer, oversteer. Sway bar size front and back, any customizations such as adding an additional link in the upper rear to maintain camber.
DocManakos@aol.com
Old Jun 1, 2005 | 10:13 PM
Default RE: Autocross suspension set ups
wow....im afraid that i cant help you on that question series. i would check with jegs or summit about engine parts, and what year car are we talking about?
Old Aug 8, 2005 | 11:32 AM
One word of advice I can ofer is that if you are wanting to be a serious autox driver and the car is also street driven, I would highly recommend getting as many adjustable parts as possible. Adjustable sway bars, struts/shocks, and so on.
Old Sep 4, 2005 | 12:03 AM
docmbnbkos's Avatar
Well I can tell you what I have done so far with the engine. I got the AFR 190 heads, the roller cam recommended, 1.6 roller rockers for more lift, stroke the crank to 3.75, carb and manifold change. Plenty of HP and even more torque. As for the suspension, I have a sway bar upgrade to 1 1/8 inch front and 1 inch rear. I have a fiberglass spring in the back that was in the car so I don't know what the spring rate is. I'm not sure what springs are in the front, but I did have stock rear sway bars so I must have had the performance package for 1979. So if anybody knows what that spring rate would be I would appreciate the information. I was interested in adding a upper link in the rear soon. I put the 1 1/8 - 1 inch sway bar combination as per a Herb Adams recommendation, but I called Guldstrand and they thought the bars were to big in the back and the fiber glass spring is a no no. Any thougths on the subject?
Docmanakos@aol.com email is better
Old Aug 10, 2006 | 06:05 PM
I have a '80 L82 and put in a "Max Performance Suspension Package" from EKLERS.
Mono-spring front and rear, fully tuneable as to ride height and spring responce on all 4 corners. 1 1/4 front and 3/4 rear sway bars. I don't know about Auto X but works really great on the road. This is a complete kit that bolts in, no mods needed. Shocks, springs, a-frames, and more. Check it out at EKLERS.
Old Aug 22, 2006 | 10:37 PM
Crash's Avatar
I have wanted to auto cross for a while now and on the weekend i finaly got out to an event in grand forks nd . first off I was running my bone stock 86 conv. vette with street tires ( everyone else had race tires on ) I had a blast , the people were great and the track very intresting . I had a friend who has been doing this for 16 years showing me the ropes ( he placed first over all )
Like I said WHAT A BLAST . now I just have to get my race tires on and do it again.
Old Jan 28, 2007 | 02:27 AM
kchotboat's Avatar
I am installing poly bushing, adjustable flat front spring, larger sway bars, camber brace and wider wheels. I am in BSP with this car.
Old Jan 28, 2007 | 02:42 AM
kchotboat's Avatar
http://www.vbandp.com
They are great to work with.
Old Aug 22, 2007 | 09:08 AM
Tinstar's Avatar
http://www.vbandp.com/
Buy their complete package.
You will be amazed.
Here's some stuff about my C4 if you want. www.buckmorris.com
The one thing I will change is the shocks.
I am going to KONI DA's but I am pretty competitive.
Old Jul 28, 2016 | 07:08 PM
Nokones's Avatar
On my 89 Z51 I am running a 1,417 pound front spring with adjustable pods for adjusting the ride height, adjustable upper control arms, special lower control arm bushings by Mike Maier, Inc., Penske Triple Adjustable shocks specially valved by Mike Maier, Inc., a custom Mike Maier adjustable front swaybar with remote control, 830 pound rear spring with long bolts for adjusting the ride height, Vette Brakes and Products Heim-joint dog bones, Camber and tie rods, Baer 6-piston calipers with 14" rotors on all 4, Forgeline Wheels (18X11" in front and 18X12 1/2" in the rear). My car weighs under 3100 pounds with a 6-point cage.
mkljtyc
Jul 12, 2013 07:44 AM
taarika01
Jul 4, 2013 05:11 AM
SCHOON
Sep 20, 2007 07:54 PM
crossfire383
Oct 5, 2005 12:33 AM
bthurston024
Sep 18, 2005 10:51 PM
