rear end ratios
Old Nov 16, 2005 | 07:29 PM
supermano57's Avatar
Default rear end ratios
are the ratios the same on a 76 and a 77???? i was thinking about putting my 77's differential on my 76 bc my 76 is making some loud knocking sounds when i turn...is this possible????
Old Nov 21, 2005 | 10:44 PM
Gkayea's Avatar
Default RE: rear end ratios
Without knowing what trans you have, I'm going to guess if its a close ratio 4 speed your diff. gear ratio is 3:36:1, if it is the auto it is a higher ratio meaning the numbers are lower. The knocking in your rear could be the clutches sticking and not releasing when you corner, you may want to suck out the fluid with a drill pump and refill with new lube and posi additive, if you do it your self cost around $15.00 it may be all you need. You probably have a posi rear if it knocks when you corner.
Let me know.
Glenn 73 LS4
79vette
Dec 17, 2005 10:54 AM
way235
Nov 10, 2005 04:14 PM
Kyle93
Oct 19, 2005 11:26 PM
nmoser01
Sep 6, 2005 06:13 PM
jerrys
Corvette C6 Z06
Sep 3, 2005 07:13 PM
