rear end ratios
Without knowing what trans you have, I'm going to guess if its a close ratio 4 speed your diff. gear ratio is 3:36:1, if it is the auto it is a higher ratio meaning the numbers are lower. The knocking in your rear could be the clutches sticking and not releasing when you corner, you may want to suck out the fluid with a drill pump and refill with new lube and posi additive, if you do it your self cost around $15.00 it may be all you need. You probably have a posi rear if it knocks when you corner.
Let me know.
Glenn 73 LS4
Let me know.
Glenn 73 LS4
