Which Intake Manifold
Old Nov 26, 2005 | 11:03 PM
Default Which Intake Manifold
I am thinking about getting a new intake manifold pretty soon and can't decide between the Weiand/Lingenfelter 300-111P or the F.A.S.T. LSX.
Keep in mind that I probably will never use any type of forced induction on my car, my goal is to reach 500 RWHP N/A. Thanks for your help.
Old Nov 27, 2005 | 10:36 PM
Default RE: Which Intake Manifold
The Weiland/Liengefelter is pretty close to a stock LS6 manifold, just cast metal instead of plastic. You can polish it for a nice look and because it is metal you can pressurize it a lot, otherwise it has not advantage over the LS6, as I understand.
Call Lingenfelter and talk to to Ed Potter and I think he will tell you this also (he can sell you the Weiland or a FASt manifold: I got my FAST from him).
If you are going to go for 500 RWHP N/A, you will need to get something with a 90 mm throttle body: a FAST 90 mm version which means a good bit of money for the 90 mm throttle body, but you'll need it (the throttle body will cost as much or more than the manifold).
Data points:
My current 427 C5R engine before the SC, it had then (and has now) only 10:2 compression ratio and not-too-radical cam, but 427 cubic inches with fantastic heads (patriot III with custom porting, flowed 347): produced 485 RWHP @5800 with a stock LS6 manifold, 507 RWHP @ 6200 with the FAST, all normally aspirated.
The 408 in the Camaro (11.25:1, AFR big-port heads) is more dramatic difference. With an LS6 it produced only 465 RWHP at 5400. With a FAST 90 mm it did 512 at 6500. This engine was just starving for air and could not even get into the cam's power band with the LS6 manifold.
Old Nov 27, 2005 | 11:42 PM
Now I was reading a description of the FAST manifold and it was saying that unless you are either using forced induction or a stroker that you should use the 78mm version. Based on that info I was going to go with the 78mm...with that being said you don't think the 90mm will be to much if I don't plan to stroke or bore the engine?
Old Nov 28, 2005 | 09:29 AM
Well, my reply was based mostly on your wanting 500 RWHP. I don't think you will get that N/A through a 78 mm throttle body, and you will certainly get more power out of any heavily modded engine with the 90mm. I have not seen 500 RWHP through any stock or even slightly ported (there is some way folks open it up a mm or two which helps a little and someone else makes an 83 mm body, I hear).
that said, yes, FAST is right in their literature: the smaller tube manifold (which can use the stock throttle body) is not just adequate, but more appropriate for stock or lightly modified engines: but you won't get anyway near 500 RWHP from such an engine.
Given that you want 500 eventually, I'd stick with the stock right now or pick up a used LS6 manifold cheap until the time you need the 90 mm one.
I will post elsewhere a new threard some data on various HP figures I've gotten or seen with my own eyes.
Old Nov 28, 2005 | 05:32 PM
Lee,
If he has a 2001 and newer, I believe he already has an LS6 intake and block (at least starting with the later-model 01s). I know that my late-year 01 has both from the factory. This was part of the 5 HP and 25 lbs-ft of torque increase over the 2000 C5s.
Old Nov 28, 2005 | 09:07 PM
Yeah, come to think of it, you're right. He already had that doesn't he?
Old Nov 28, 2005 | 09:12 PM
No, I have a '98
Old Nov 29, 2005 | 01:45 AM
Ah, but we couldn't tell from your signature - nice pic, by the way!
Old Nov 29, 2005 | 09:57 AM
Until you just said that I didn't even realize that I didn't have it in my sig, I'll go change that....thanx
harleymarkt
Mar 13, 2008 10:25 PM
C3 Starship
Dec 20, 2006 08:37 PM
imb1987
Jan 25, 2006 02:57 AM
Krayon
Nov 5, 2005 09:24 PM
mrs_torchd
Oct 25, 2005 01:31 PM
