step by step...my new stereo install w/pics
Old Mar 23, 2008 | 10:15 PM
ZR1clone's Avatar
Default step by step...my new stereo install w/pics
Here it goes...
take off the trim pieces and removs the old Bose
[IMG]local://upfiles/6540/EF3B1D86AE014035B2E9A9C78E141250.jpg[/IMG]
remove the fuse trim and the passenger side vents
[IMG]local://upfiles/6540/3CBE41C6FB7F41A7A666EB0CB63667DC.jpg[/IMG]
[IMG]local://upfiles/6540/2C41831139D348A48964DCB051163BC3.jpg[/IMG]
remove the bottom trim and locate the Bose reciever box
[IMG]local://upfiles/6540/A6C1E8C6A86740B7BFEBDC93C3E4BEB6.jpg[/IMG]
[IMG]local://upfiles/6540/FAE1E3BFD6A14F5D9CB6862DA6D94090.jpg[/IMG]
Old Mar 23, 2008 | 10:23 PM
ZR1clone's Avatar
Default RE: step by step...my new stereo install w/pics
next...pull the three plugs from the Bose reciever
[IMG]local://upfiles/6540/5DA78319085E4A14841D0440F6CC6E00.jpg[/IMG]
plug these three little jewels into the wire harness
[IMG]local://upfiles/6540/CB6F8C6F224349D8B1AEFF2067388642.jpg[/IMG]
[IMG]local://upfiles/6540/3F7D014B652D46D6B1D1F9C13B7C95CA.jpg[/IMG]
start cutting and labeling wires to extend the wire harness. I used about 4ft. MAKE SURE YOU LABEL THE WIRESCORRECTLY BEFORE YOU PULL
[IMG]local://upfiles/6540/53B2ADA738F24D73B227662F5F2C4760.jpg[/IMG]
Old Mar 23, 2008 | 10:36 PM
ZR1clone's Avatar
Then...Pull the wires through to the stereo "hole" and to the new wire harness
[IMG]local://upfiles/6540/17BB1903E1D54A888CF428B4A2E50699.jpg[/IMG]
[IMG]local://upfiles/6540/22965F3087534441AA329EF5F7803270.jpg[/IMG]
Connect your labeled wires. Make sure connections are tight andsealed.
[IMG]local://upfiles/6540/E31D41F6C7D14715B9D5A91F5EC8EAFA.jpg[/IMG]
Next connect the ends of the stereo harness to your pulled wires. Make sure they are secure.
[IMG]local://upfiles/6540/F60C87F9B92A40AF9262DD4D2AECBC17.jpg[/IMG]
Old Mar 23, 2008 | 10:42 PM
ZR1clone's Avatar
after that... I worked on the mounting bracket...
[IMG]local://upfiles/6540/41D4E0A3D9D748B09C320D3F52BBCA43.jpg[/IMG]
Severe "MACGUYVERING"was necessary to make all things fit just right. You will see what I mean when you try. Here are some of the things that I did. They worked for me. Feel free to make improvements as you see fit.
[IMG]local://upfiles/6540/B04C4493213F45D3B7BC3C5A3538765F.jpg[/IMG]
A little cardboard to fill the gap and add support since only one mounting bracket screw hole lined up right.
[IMG]local://upfiles/6540/5AFC4815BAEE4448A018A06044FB03BF.jpg[/IMG]
I used some styrofoam to make "pillars". This was cut from the styrofoam padding the new reciever in the box. I used two pieces on the left side to hold up the bracket and shelf where there was no screw to mount to... you'll see.
[IMG]local://upfiles/6540/248F6333CF564F9083DB25E7866DF79E.jpg[/IMG]
Old Mar 23, 2008 | 10:55 PM
ZR1clone's Avatar
Finally...[sm=bling.gif][sm=Flahssssss.gif][sm=happybounce.gif][sm=hail.gif][sm=happy046.gif][sm=signs003.gif][sm=wootwoot.gif]Thanks to all those that posted info previously about this topic. I hope that this can help a lot of people in the future. Please feel free to comment on this. THANKS CORVETTEFORUMS.COM
[IMG]local://upfiles/6540/942371BF7F8F4DF48817DA619890D8BB.jpg[/IMG]
[IMG]local://upfiles/6540/210344633EF44AFB8478FF971D185839.jpg[/IMG]
Old Mar 23, 2008 | 11:33 PM
Great job! enjoy your new tunes. Cheers
Old Mar 24, 2008 | 07:53 AM
LeesVette's Avatar
Looks good!
Old Mar 24, 2008 | 01:24 PM
harleymarkt's Avatar
has anybody put a in-dash tv in their c4 im thinking about it any input would be nice any pic would be nicer
Old Mar 24, 2008 | 02:24 PM
Great job and great pictures, I'm sure that will help out the next person, PG.
PinnacleWax
Sep 15, 2014 01:58 PM
donb1226
Sep 7, 2008 06:10 PM
nharmsway
Jul 30, 2007 08:01 PM
D327
Oct 3, 2006 03:10 AM
imb1987
Nov 20, 2005 05:32 PM
