327 / 340 cam specs
Old Aug 24, 2018 | 02:29 PM
pacecar620's Avatar
Default 327 / 340 cam specs
Does anyone have the specs and part number for the 1962 327/340 solid lifter cam? Would the '69 Z-28 cam be a good fit for this engine?
Old Aug 25, 2018 | 11:32 AM
Based on my 1975 parts catalog, the part number would be 3736097. The part number for the 1964 & 1965 fuelie, and 1970 LT-1 which would probably be the same as the 69 Z-28 cam or very close to it is 3972178. It is very possible that these part numbers have changed over the years although they did stay the same up until my latest catalog which was 1983. Hope this helps.
Old Aug 27, 2019 | 09:50 AM
MFJ's Avatar
MFJ
The original Duntov cam was a .012"Intake---.018" Exhaust lash cam, the last factory installation would have been 1963. In 1964 they went with the .030--.030" lash camshaft that continued as stated above into the 302 Z28 and 1970/71 LT1. This cam which has very loppy idle in the 302 Z28 smooths out the idle and with improved mid range torque when installed in larger displacement 350 small block engines. I pulled a 030--030 cam out of a 365 HP 327 and installed a Duntov cam and found that the mid range torque was improved and also overall driveability was improved in a C2 Corvette.over the 30-30 cam.
szach13
Apr 3, 2008 09:53 PM
RMASO123
Sep 1, 2007 01:27 PM
01darkz
Corvette C5 Z06
Jan 18, 2007 11:43 PM
BIG.G.73
Oct 27, 2006 07:56 PM
89rdstr
Jun 20, 2006 10:46 AM
