Broken gas tank sending unit ground tab
Old Jan 16, 2022 | 01:42 PM
Ammo's Avatar
Default Broken gas tank sending unit ground tab
1965 Convertible:
Hope for some professional advise... While I was inspecting my gas tank sending unit when I pull off the grounding wire the grounding tab came/broke off. Just short of replacing the sending unit is there any way to repair or re-locate the grounding tab?
Thank you in advance
Old Jan 18, 2022 | 01:53 AM
You could try conductive epoxy.
Old Jan 26, 2022 | 09:49 AM
Ammo's Avatar
73shark,
I did the research on your excellent idea on conductive epoxy. I believed I talked myself into replacing the sending unit but I want to that you (again) for your innovated and professional input.
Ammo
Old Jan 27, 2022 | 11:39 AM
Thanks. Probably the best thing in the long run. 👍
Old Feb 8, 2022 | 12:18 PM
jblynch's Avatar
Is there enough tab left to drill a small hole and just wire-wrap + solder the ground in place? (Probably not. Most likely the tab broke off at the spot weld ... assuming there is one).
60n61 Man
Jun 12, 2017 03:33 PM
wilton
Aug 30, 2009 05:32 AM
KenHorse
May 15, 2007 08:07 PM
littleRedCoupe
Oct 16, 2006 09:35 AM
FLbTLINE
Sep 10, 2005 01:22 AM
