C2 Posi rear locked up
Old Sep 4, 2020 | 08:32 PM
Daron's Avatar
Default C2 Posi rear locked up
I have a 65 300 horse with a 3:08 Posi. Went to take a spin today and would not roll. Thought I had a frozen caliper but left rear wheel will not spin and I can wiggle enough to see pads not seized on rotor.
Right side spins when jacked up. Any insight?
Thanks, Daron
Old Sep 5, 2020 | 09:32 AM
When you said it won't roll was that with the engine running and in gear? Only thing I can think of is maybe the wheel bearings are frozen.
Old Sep 5, 2020 | 10:12 AM
Daron's Avatar
Thanks for the reply. I had only tried putting in gear and going forward as there was a motorcycle parked behind. I was able to get it unstuck this AM but putting in reverse and gently letting out clutch. I believe it was in the rear end but no pop or alarming jolt when backing up. Have not taken out for a drive. I usually back car in then roll back the last two feet. Usually left in neutral.
PHILC
Dec 17, 2007 08:55 PM
PHILC
Oct 30, 2007 02:18 PM
spanky01
Jul 23, 2007 02:53 PM
maine
Jan 1, 2007 10:49 PM
johnc
Oct 12, 2006 12:08 PM
