brake problems
Old Oct 11, 2006 | 11:51 PM
johnc's Avatar
Default brake problems
anyone have any info on DOT3.DOT4 differences?have replaced entire brake system,and continue to have spomgy pedal.bled system 6,7 times.cannot lock up wheels.any thoughts appreciated,jc
Old Oct 12, 2006 | 01:44 AM
Default RE: brake problems
My first thought is......
There is an order in which you bleed each wheel.
Left front, Right front.
Then check the brake lline routing, to see which side of the frame the tubing runs.
If it runs down the left side, bleed the Left rear then the Right rear.
If it runs down the Right side, bleed the Right rear and then the Left rear.
Always bleed the wheel closest to the master cylider first and the furthest wheel last.
Watch your fluid level, don't let any air back into the system.
Hope this helps!
Old Oct 12, 2006 | 12:08 PM
Phill's Avatar
when i replaced the calipers on my z28 i didnt crimp the lines and all the fluid leaked out so it took about 30 minutes of constant pumping and bleeding to get all the air out of the lines.
Todd TCE
Aug 25, 2015 09:55 AM
todd81
Apr 29, 2012 02:47 PM
JR Spokehead
Apr 9, 2006 05:07 PM
HeeBGB
Oct 30, 2005 09:32 PM
Patrick
Jul 2, 2005 10:15 AM
