C2 - slight whine in first gear
Old Nov 5, 2018 | 08:04 PM
Farmone's Avatar
Default C2 - slight whine in first gear
New to me and first ever GM product - 65' C2, 4 speed. It has a slight whine in first gear, natta in 2,3,4. Is this typical, or the beginning of an issue. Match number tranny with 70,000 miles.
Old Nov 6, 2018 | 09:08 AM
Unless it's the M22, aka Rock Crusher, then I would say it's probably not normal.
Old Nov 9, 2018 | 05:46 AM
Farmone's Avatar
How do I identify if M21, M22, etc?
Old Nov 9, 2018 | 11:11 AM
I don't know of any way to externally identify the transmission type. It might be possible if you had the dust shield off and could see the clutch pressure plate. Then you could put it in gear and have someone rotate a rear wheel and monitor the Revolutions of the clutch plate. Of course that would require a third person inside keeping the clutch depressed so you weren't trying to turn the engine over at the same time. IIRC, the low gear ratio is about 2.5 to 1 (M20) and the low gear ratio is about 2.2 to 1 (M21 & M22). The reason the M22 is called Rock Crusher is because it utilizes straight cut gears and is therefore a lot sturdier.
bobslsc
Mar 21, 2013 04:32 PM
vettski
Apr 17, 2012 08:59 PM
njscott
Jun 20, 2007 04:18 PM
thumper101
Jan 31, 2007 03:10 PM
Pecemkr
Aug 5, 2006 04:43 PM
