custom headlight door motor 63 Corvette
Trying to figure out a custom motor to operate the headlights on my 63 The body is on a tube frame so using orig parts is out of the question.. I was trying a Mazda headlight motor but it go's 180 deg. but when you feed the other wire it continues the rest of the way 360 deg I need one that go's 180 one way and back 180 deg.. Any sugestions..
It's been a while since I've seen a mid-year headlight motor setup but would it be possible to add a custom bracket to use the original? I know you said using the original was out of the question but I didn't know if that would be possible or not.
