How to quiten C@ Side Pipes
Old Jan 20, 2022 | 10:55 AM
cajenn's Avatar
Default How to quiten C@ Side Pipes
Anyone have any ideas of how to quiten C2 sidepipes. I have a 1965 Vette with350HP 327 and LOUD side pipes. Just too loud for this neighborhood. Any ideas?
Thanks for your help....Cajenn
Old Jan 21, 2022 | 10:06 AM
Welcome to the forum.If they are factory side pipes then there's nothing you can do to quiet them as they are just a tuned straight pipe.
Is that what you have?
Old Jan 21, 2022 | 09:15 PM
cajenn's Avatar
Yep, they are factory installed. I have heard of inserts of some sort but really don't know how they would work. Also concerns about excess back pressure.
Thanks for your response.
Cajenn
Old Jan 21, 2022 | 10:06 PM
The only side exhaust I know of that has an insert is the Hooker Nest of Snakes type. Basically the insert is just a straight through fiberglass muffler that slides into the 4" side pipe.
The mid-year side pipe is basically a straight 2 1/2" pipe that has various areas pinched down to cancel out particular frequencies. Basically a tuned pipe.
Old Jan 24, 2022 | 11:39 AM
cajenn's Avatar
Thanks for the response. May have to just get rid of the side pipes.
Old Jan 24, 2022 | 04:11 PM
I've been around and driven mid-year small block and big block cars with factory side exhaust and at normal residential speeds didn't find them very loud. Are you sure that these are actual factory side pipes? You can tell by checking to see if they have random pinched down areas along the length of the pipe.
If they are factory and are in good condition, both the pipes and the covers are worth some money these days. If you check some of the aftermarket suppliers you will find that they get quite expensive.
Old Jan 29, 2022 | 09:57 AM
cajenn's Avatar
These are original....crimped pipes, etc. Will look into selling these if I change them out.
Thanks,
Cajenn
chevyguy171
Aug 11, 2011 05:52 PM
Ttoptom
Feb 12, 2008 02:45 PM
frank85
Jan 14, 2007 01:12 PM
srizzutto
Jul 29, 2006 12:26 AM
buck
Jul 3, 2005 09:45 AM
