10" rally wheels
Old Dec 5, 2007 | 02:47 PM
allill's Avatar
Default 10" rally wheels
I have a set of rally wheelsbeing offered to me, 15x8 and 15x10. Does anyone know if the 10" rims will fit the rear ok?
Old Dec 5, 2007 | 06:05 PM
Default RE: 10" rally wheels
Check the back spacing against your current rims.
Old Dec 5, 2007 | 06:08 PM
The stock 15X8 Rallys had about a zero offset, so the 15X10s would need about a two inch negative offset or about a four inch backspacing. If they fit, they will definitely stick out past the body. []
EDIT: I meant the 15X10s as now edited. [X(][:-]
Old Dec 5, 2007 | 06:39 PM
I have the stock 15 x 8 ralley wheels that I got from Ecklers. No clearance probs, and tires are still inside the wheel wells.
Old Dec 6, 2007 | 08:25 AM
These are pretty wide, and look great. Still in the wheel well.
Cooper Cobra Gt Radials,P265/50 R15 Rear, on the 8" ralleys.
I don't have a photo with these wheels and tires on my Vette.
Oh, wait........yes, i do. I'll have to findthem in my files, and will post the pics when I get home after work.
Gotta go right now. [&o]
Old Dec 6, 2007 | 06:42 PM
This is the only one I found. [&o]Not very good, I'll go ahead and take some pics and post them in the next couple of days.
A full 10" of rubber on the ground.
Old Dec 6, 2007 | 07:38 PM
allill's Avatar
What is the backspacing/offset of the 15x8 stock rallys?
Old Dec 6, 2007 | 08:02 PM
If memory serves me, it's about 4"/0". I've got a set under the deck but there's about 4" of snow out there. If you need an actual measurement, let me know and when it warms up, will check. Or maybe someone else has the info.
Old Dec 6, 2007 | 08:07 PM
C3: I'm curious to know how much clearance you have to the parking cable bracket on the trailing arm.
Old Dec 6, 2007 | 08:23 PM
I'll include that in the pics I take. I'll do the whole rearend, suspension and wheel clearance. I have the rear up in the air, so I shouldn't have any probs getting the pics. I'll try to get some measurements too.
