1973 Corvette Rear End Problem?
Old Jan 14, 2013 | 09:34 PM
Dzbo's Avatar
Default 1973 Corvette Rear End Problem?
Hello everyone,
I just started driving my 1973 Stingray again after a week of decomish due to a blown water pump and bad alternator. As I tried to get into second gear I could feel and hear a vibration. Seems to be coming from the rear, and my father said the same thing. The previous owner had this car setup for racing, has a shift kit and first gear starts to high rev at 30 and then shifts at 50. 350 cui from a 71 Elco, Carter 4-barrel carb, edlebrock performer RPM intake, MSD 6-plus ignition control, long tubes...pretty sure that the tranny is original to the car (3 speed). Anyway, at highway speeds I can still feel the vibrations. My dad thinks it might be either the U-joints are going bad, or the fluid in the rear end might be low. Tranny fluid is good, and just changed the oil. If anyone can please help, it would be much appreciated.
Thanks.
Attached Thumbnails 1973 Corvette Rear End Problem?-img_0166.jpg   1973 Corvette Rear End Problem?-img_0168.jpg   1973 Corvette Rear End Problem?-img_0163.jpg
Old Jan 15, 2013 | 03:15 PM
Might look at the rear wheel bearings also. Does it do when coasting? In neutral? Hard acceleration?
Old Jan 15, 2013 | 04:12 PM
Dzbo's Avatar
Might as well do that too while I'm back there. No, doesn't do it when it is coasting or in neutral. I mostly feel it when I am trying to get to second and at highway speeds.
Old Jan 15, 2013 | 05:00 PM
And it didn't do this before it sat for a week? Meant to ask what's a '71 Elco?
Might check rear diff lube level also.
Old Jan 15, 2013 | 05:18 PM
Dzbo's Avatar
Nope did not do this before it sat. '71 El Camino.
Old Jan 15, 2013 | 06:08 PM
Dzbo's Avatar
Oh an I just checked the rear diff fluid level and it is good, looks like it could use a change though...
Old Jan 15, 2013 | 06:48 PM
If you do decide to change, don't forget to put in a bottle on GM's Posi-Trac additive. Keeps the clutches from grabbing.
Old Jan 15, 2013 | 09:45 PM
Dzbo's Avatar
I'm thinking of getting Royal Purple Max Gear-Synthetic 75W-90, with the additive. How does that sound? Or is there a certain weight I should use?
Old Jan 16, 2013 | 12:23 AM
The weight sounds right but I'd stick w/ the GM additive. I tried something one time that supposedly had the additive in it and the diff. started clunking on slow turns.
Old Jan 17, 2013 | 08:49 PM
Dzbo's Avatar
Well, something new has occurred today when I was driving home. I noticed some chatter coming from the rear-end when I was waiting at a stop light. It was faint but I could hear little clunks and whenever I made a right turn and while on the gas, the chatter was back. I put in reverse and backed up about 60 feet to see if there would be any noises but nothing. Also it feels that the differential isn't even grabbing. I was driving about 25 and the revs were going up but the car was going no where, and this never occurred before. I fear now that the entire differential is going bad. Any insight?
