1974 Oil Breather set up
Old Jul 19, 2008 | 06:21 PM
  #11
1974redvette's Avatar
Default RE: 1974 Oil Breather set up
I ended up using the stock valve covers with the stock metal tubing attached to a breather via 3/4 hose. This works rather well, all you have to do is reverse the metal tube and hold it tight with a hose clamp. I also added the edelbrock performer eps intake with the matching 600 cfm carb. and removed the smog system. This makes for a totally different car and I would highly recomend.
Old Jul 20, 2008 | 09:19 PM
  #12
pg's Avatar
Hi DeeVeeEight, that is one beautiful engine compartment! PG.
Old Jul 20, 2008 | 09:23 PM
  #13
pg's Avatar
Hi 1974redvette, glad you were able to fix that breather problem, it's very important to keep the air going into the engine clean, PG.
Old Jul 21, 2008 | 05:56 PM
  #14
DeeVeeEight's Avatar
Banned
Thanks - Flying Low and PG - Your compliments are appreciated!
[sm=icon_cheers.gif]
Old Mar 28, 2024 | 07:30 AM
  #15
Liquidasset89's Avatar
I like your plug wire set up. What wire holders do you use?
xbob17x
May 21, 2007 02:06 PM
theshopindy
Aug 3, 2006 04:23 PM
SLJ2137694
May 16, 2006 02:32 PM
piperaro
Sep 3, 2005 09:53 PM
jerrys
Corvette C6 Z06
Sep 3, 2005 07:13 PM
