1976 Corvette Neutral Safety/Backup Switch Question
Old Jun 28, 2007 | 03:10 PM
grannyklump's Avatar
Default 1976 Corvette Neutral Safety/Backup Switch Question
The Neutral Safety/Backup Switch went bad in my 1976 (automatic)corvette. I ordered a new one from an online dealer and it looks different from the one i removed from the car. the new one has 2 pair of wires where as the old one has 3 pair. We installed the new one and it works fine but i am a little worried as to what the other pair of wires went to on the old one.Does that other 3rd pair hook up to the Alarm switch on the driver side fender by chance? or does it have someother purpose.
Thanks
GK
Old Jun 29, 2007 | 10:37 AM
Phill's Avatar
Default RE: 1976 Corvette Neutral Safety/Backup Switch Question
hi granny. just out of curiousity what did the car do when the switch went bad. im having starting problem on my 79 whenthe cargets hot. my switch also has an extra connector and an extra wire compared to the ones ive seen on-line.
Old Jun 29, 2007 | 10:56 PM
RogerO's Avatar
I dont have a 76 diagram but I wonder if the 3rd set could be for the starter interlock relay.Do you have one on the firewall,has an orange base and a little button on it?
Old Jun 30, 2007 | 10:03 AM
drummerjlc3's Avatar
I have a Corvette factor electrical manual and it shows that 72 and 73 had the 3 wire harness which was for the seat belt warning buzzer but it did have option for the ani-theft switch which pluged in under hood by the under hood light switch located @ passanger top corner by the blower housing, should be purple wire. Hope this helps.
Redwhisper
Aug 28, 2014 05:12 AM
SCHOON
Apr 16, 2012 03:34 PM
Bagpipingjake
May 14, 2007 07:04 AM
chanlabing
Sep 24, 2006 08:29 AM
tdr1919
Sep 11, 2006 12:21 AM
