1979 corvette not down shifting
Old Apr 30, 2007 | 09:24 PM
riley6riley's Avatar
Default 1979 corvette not down shifting
I bought a 1979 corvette a few weeks ago and I am working on bringing it back to life. It had been sitting in a garage for the last 3 years so it needs some TLC. I put a new holley carb on it last week and it runs great but when I floor it the carb opens up but the car does not down shift. I can down shift automaticaly and it gets up and goes really good. Does this sound like a tranny problem or a carb adjustment? I hooked the tranny linkage up to the new carb like the last one and the guy I bought it from said it used to work fine. Any ideas.
Thanks
Old May 1, 2007 | 12:28 AM
pg's Avatar
Default RE: 1979 corvette not down shifting
It sounds like your downshift cable it out of adjustment, since you can downshift manually I don't think it's the carb or trany. PG
Old May 1, 2007 | 06:46 PM
Thanks. I have a haynes manual and I will see if it is in there how to adjust it.
Old May 2, 2007 | 11:53 PM
Is it a Turbo 400 or a Turbo 350? The passing gear rod should contact the throttle arm at almost full throttle and only should move a short distance. Also the throttle valve mightbe stuck in the trans. If so, might need to take it to a transmission shop and ley them fix that.
deansreef
Oct 15, 2010 11:20 PM
deansreef
Mar 23, 2007 11:56 PM
Nishioka79
Aug 25, 2006 02:51 AM
Bubbie
Aug 5, 2005 08:34 PM
sl0010
Jul 13, 2005 10:11 AM
