2 bolt or 4 bolt main in a 74 L48 engine
Does anyone know if a 74 L48 engine is a 2 or 4 bolt main?
Is there any way to tell using the casting numbers? or do i have to pull off the oil pan and look?
Hi '74, you'll have to drop the pan to know for sure but here is a little info from my own experience. The factory L48 in my '78 has block casting #3970010, the books all say this block was cast from 1968 thru 1976. GM installed these in everything they turned out. I've torn down three engines with the same casting number and they have all been four bolt's. I have not pulled my L48 apart so I can't say for sure but my money is on it being a four bolt.
Check your number through www.mortec.com , should get an answer there.
Yeah... L48's were 2 bolts. But that same block was used for the LT1's in '70-72 in the 4 bolt set up... no difference in the oil galleys on that one.
I'm hoping to pull the factory motor out this winter and replace it with a stroker, I'll be pullin' the pan off for sure 'cause I'm curious as to what GM had left over and stuck in the late '77's. I'll let you know as soon the last pan bolt is out.
