2 bolt or 4 bolt main in a 74 L48 engine
Old Nov 30, 2007 | 09:08 PM
  #11
Default RE: 2 bolt or 4 bolt main in a 74 L48 engine
The L48s had the narrow, six inch balancer and the L82s had the thick, eight inch one. I think that hold across the board for most high performance and special high performance small blocks.
Old Dec 1, 2007 | 12:27 AM
  #12
1974corvetteowner's Avatar
so is there any realtionship between the smaller balancer usally being on 2 bolts main and larger on 4 bolt main???
Old Dec 1, 2007 | 11:54 PM
  #13
None other than that as far as I know.
I'm in mourning right now.
Old Dec 2, 2007 | 12:57 AM
  #14
ORIGINAL: 73shark
Why are you in mourning? what happened?
Old Dec 2, 2007 | 11:53 AM
  #15
Check my avatar. My Tigers got beat bad last nite.
Old Dec 2, 2007 | 11:56 AM
  #16
lol o ok
Old Dec 2, 2007 | 12:57 PM
  #17
Ok back to the topic at hand any way to figure out if it is 2 or 4 bolt main from the serial number off the front passenger side of the engine block? Well my serial number is 1z1775352 (i think a little hard to see)
Old Dec 2, 2007 | 06:40 PM
  #18
78buckshot's Avatar
The stamped in engine number won't tell you if it's two or four, only that the engine was originally installed in a particular model with the tranny type and in our case if it's a L48 or L82. Are you just curious as to what you have or are you planning on building the motor up? A two bolt bottom end can stand up to 500 hp if everything is in proper order.
Old Dec 2, 2007 | 10:10 PM
  #19
Well I am just curious now but in the future I plan on building up the motor
Old Dec 2, 2007 | 10:23 PM
  #20
blknblu68's Avatar
well with todays technoligy they can splay the 2 bolt blocks making them a stronger 4 bolt than a factory built one so i wouldnt sweat it bud!!
