350 Rebuild
Old Dec 14, 2006 | 06:21 PM
El_Lobo's Avatar
Default 350 Rebuild
Me and a friend are giving a 77 vette some attention this winter. One of the things were doing is pulling the engine (l48), rebuilding it and adding some upgrades to give it a little more power. I thought i'd post what we were planning on doing and see what you guys thought. Any suggestions or help would be greatly appreciated. Thanks in advance!
Kinda on a budget cause we have other things planned too so I think were going to leave the heads alone for now. So here goes....
Edelbrock Performer RPM Intake Manifold EDL-7104
http://store.summitracing.com/partde...5&autoview=sku
Summit Cam and Lifter Kit SUM-K1103
Summit True Roller Timing Set SUM-G6601
Summit Performance Headers SUM-G9003
http://store.summitracing.com/partde...DG9003&FROM=MG
Hooker Competition, Header-Back Kit HOK-16521HKR
http://store.summitracing.com/partde...521HKR&FROM=MG
Hooker Super Comp Turbo Mufflers HOK-21105HKR
http://store.summitracing.com/partde...105HKR&FROM=MG
Old Dec 14, 2006 | 06:55 PM
El_Lobo's Avatar
Default RE: 350 Rebuild
Forgot to mention we'll also be getting some pistons to raise compression also
Old Dec 14, 2006 | 07:38 PM
corvette king's Avatar
it all looks good..but i would go with the rpm air gap intake..same rpm range but you wil get more top end and has the air gap for cooling......how much comp you going with...are you useing a flat top or dome piston what are the cc of you combustion chambers.....you might need a different cam.....with that kind of combo. let me no i can guid you in the right way to go...how much extra hp do you want and how streetable.
Old Dec 14, 2006 | 08:40 PM
El_Lobo's Avatar
Noticed in the notes for the rpm air gap intake :"Will not fit under stock hood of Corvette." So I'm guessing that one is ruled out
Not too sure about the comp to be honest with you, was going to talk to a friend at work about it this week, I was thinking 9.x:1? Chambers are listed at 75cc. We're not going for anything crazy fast but I was hoping to hit somewhere in the 250-300hp range. Not really sure if what I have listed will make it close to that or not since the stock it only pushing 180hp.
Thanks for the help king.
Old Dec 14, 2006 | 09:00 PM
YA I THOUGHT THAT THE RPM WAS TOO TALL...THAT SUCKS....IF YOU KEEP IT 10 TO 1 COMP...WITH A LITTLE BIGER LIFT THAN THE CAM U PICKED...AND SOME 1.5 ROCKERS OR YOU CAN KEEP THE CAM YOUR GETTING AND GET 1.6 ROLLERS ROCKERS AND THAT WILL BRING YOUR LIFT TO 285....THE HEADS IS WERE ALL YOUR POWR IS DO YOU NO IF YOU HAVE 202 OR 194 VALVES.
Old Dec 14, 2006 | 11:57 PM
El_Lobo's Avatar
Searched around and found this if it helps...
Stock L48 cam specs are: Intake: 195 Duration @ .050" , Lift .390" Exhaust: 202 Duration @ .050" , Lift .410" Lobe Seperation 112
Actually talked to my friend briefly today and he was thinking most likely flat top pistons with the comp somewhere in the 9.0:1 to 9.8:1 range.
Old Dec 17, 2006 | 12:15 PM
SCHOON's Avatar
If you use Flowmaster's 50 series mufflers with the 2 1/2" pipes you will really notice the difference in preformance.
Old Dec 18, 2006 | 07:24 AM
cortlandfirefighter's Avatar
what about the 4-7 cam ?the one that changes fireing order?,suposed to give more horsepower and let engine run easier,,,,acording to folks on powerblock...
Old Dec 20, 2006 | 08:13 PM
A project detailed in the 2004 issue of Chevy High Performance, laid to rest the 4/7 cam switch. Bottom line was there was essentially no difference.
Old Dec 20, 2006 | 08:18 PM
Don't know if all piston mfg. do this, but when I rebuilt my L82, the TRW catalog delineated what the CR was with each piston and combustion chamber volume. I used the 11:1 pistons and got about 10:1 with the stock '73 L82 heads which were 9:1 with the original flattop pistons.
