70 C3 LEAN
Old Nov 1, 2006 | 07:08 PM
PTA's Avatar
PTA
Default 70 C3 LEAN
I HAVE A 70 COUPE 350/300HP AT. MY CAR SITS JUST A LITTLE LOW ON THE DRIVERS SIDE (NO SMART REMARKS! HAHA) JUST ENOUGH TO NOTICE FROM TIME TO TIME. WHAT SHOULD I START TO LOOK FOR THE CAUSE? IT DRIVES,BRAKES,AND ACCELERATES STRAIGHT IF THAT HELPS AT ALL. DOES THIS YEAR HAVE ANY KIND OF A RUBBER BISCUT IN THE BODY MOUNTS THAT MAY BE ROTTED AWAY?
Old Nov 1, 2006 | 09:24 PM
SCHOON's Avatar
Default RE: 70 C3 LEAN
I would start by looking at the body to frame bushings. One may have fell apart or fell out.
If that's not it I would look at the springs front and rear.
Rembember the car is 36 years and so are the parts that hold it together.
Also, you never know, it could be a tire.
Old Nov 2, 2006 | 06:54 PM
proto69's Avatar
I have a 69 350/350 and it had the same problem. I replace all the rear suspension rubber and bolts and it fixed my problem. I believe it was the control arm bushing.
scotth48
Jun 22, 2009 11:38 AM
07zx6arrrr
Sep 10, 2008 10:16 PM
gjswt19
Jul 14, 2007 08:19 AM
gentoo
Sep 6, 2006 11:46 PM
FLbTLINE
Nov 18, 2005 07:36 PM
