73 454 heads
Old Jul 19, 2011 | 10:47 AM
mitchmann's Avatar
Talking 73 454 heads
I have a 73 big block mostly orginal, the engine and trans were rebuilt in 1994 by previous owner. The block is orginial. The drivers side head has the proper one wire temp sensor, but the passenger side has a temp sensor that is two wire, not hooked up to anything. Any ideas where this may have been previously used. Have not had valve covers off.
Mitch
Old Jul 21, 2011 | 06:54 PM
Maybe something for some emission control???
Old Jul 22, 2011 | 09:40 AM
mitchmann's Avatar
Default 454 heads
I just assumed it was a replacement head, but you might be right. I have the shop manual, I'll search the electrical schematic and see if I can find such.
Mitch
Old Jul 23, 2011 | 09:22 AM
Just a thought,.....
The double wire sensor may be for actuating an electric fan system, replacing the belt driven engine fan. A lot of newer systems use the electric fans. You may have later modle heads.
Old Jul 24, 2011 | 08:31 PM
Not sure on BBC heads but on SBC heads, they are interchangeable, side to side. So there is a tapped hole on each head.
Old Jul 25, 2011 | 01:49 AM
pg's Avatar
Default Transmission Controled Spark System
If it's disconnected then don't worry about it, if your curious about how GM designed it then look here:
http://www.73spot.com/index_stats_fi...ission/tcs.htm
Old Jul 25, 2011 | 08:30 AM
mitchmann's Avatar
Default Thank you pg
Thanks for the link, I was not aware of the 73 spot. I will spend some time there. If anyone knows of 73 specific sites let me know.
Thanks
Mitch
Old Jul 26, 2011 | 11:23 AM
I bought mine new from the factory and it doesn't have the thermal switch on psgr side head.
When I installed factory A/C, I had the idle stop solenoid activate when the compressor was on to maintain the idle speed w/ the additional load. Also have vacuum advance connected to manifold vacuum. I think that was originally allowed only in 4th gear but it's been a long time ago. This is on a 4-spd L-82 coupe.
Old Jul 26, 2011 | 02:06 PM
pg's Avatar
Default Transmission Controlled Spark System
Hi 73shark,
That's interesting. I just looked in the 74SM (Section 6-T) and it shows the switch in the right head. What do you have in there?
Regards,
Pete.
Old Jul 27, 2011 | 02:14 PM
A pipe plug. I'll bet the switch if for auto trannies.
C3 Starship
Feb 5, 2007 03:04 PM
231SIX
Aug 21, 2006 10:18 PM
twitch2k6
Aug 19, 2006 12:53 PM
Bearcamp
May 29, 2006 09:20 PM
71yellow454
Apr 4, 2006 02:57 AM
