73 coup
Old Aug 15, 2005 | 04:13 PM
MVS's Avatar
MVS
Default 73 coup
HELP! Just bought my 1st vette...73 coup (not a midlife crisis). I had the ignition key replaced since we were able to start it without the key. However, After 3 months the car won't start. I get power when I turn the key but that's it. I'm not sure if it's the Ignition switch or something else. Speaking of the Ignition switch, Can anyone tell me where it maybe located and is it a pain to replace?
Old Aug 19, 2005 | 05:21 PM
DaveWJunior's Avatar
Default RE: 73 coup
Need more info. So when you turn the ignition to the first position, it behaves as it should? Then when you turn it to the "start" position nothing happens? When you turn it to "start" does the radio/lights/etc turn off or dim? Can you hear any clicking?
I would turn it to the "on" position and then try to short across the starter solenoid to see if you're getting power there. I've never heard of the electricals in the actual switch in the steering column going bad, so I'd have to assume that it's either a starter or a solenoid problem. The fact that you just replaced the ignition may be just making you THINK that that's the problem.
extanker
Mar 16, 2020 01:21 AM
trebor99
Oct 1, 2014 02:17 PM
extanker
Feb 9, 2008 12:13 PM
extanker
Apr 5, 2007 12:25 AM
thumper101
Oct 4, 2006 12:56 PM
